Thats one way to de-carbonize a pipe
dogmir
Post by dogmir »
Not sure how thorough this method is but interesting....
http://www.youtube.com/watch?v=fcoesvFsNUs
abreen89
Re: Thats one way to de-carbonize a pipe
Post by abreen89 »
That guys an idiot!! But this method looks feasible.
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
Carnie
Post by Carnie »
"...it's like blowing a heat gun through a pipe with a fire truck in
The back ground."
Lol so dangerous. So fun. What's he trying to catch on fire?
1987 Spree
1994 Elite SR
motomech
Post by motomech »
Wouldn't work on these stock mufflers.
first off, the stock muffler has so much more mass that high enough temps couldn't be reached.
Secondly, more often than not, stock mufflers become restricted because the fiberglass lining the inside of the muffler body becomes saturated with oil. Enough oil, that once the muffler reaches a certain temp, the oil starts giving off fumes effectively choking the exh. flow.
Carbon or oil, there are two options to try and salvage a stock muffler.
One, cut the muffler body in half[about 2/3 rd.s of the way back] and using an acetylene torch to burn out the oil/carbon. This is a really messy, smokey job that can take hr.s.
Or two, if you can deal with a little more noise, give the muffler a "steel enema". I used to use a 14" long 5/8th" drill in a big two-handed motor and drill the muffler lenght-wise from the butt end. Much, much easier.
thekingof7
Post by thekingof7 »
Is this actually dangerous?
And are you sure on that this wouldnt work on a stock pipe? ie my 87 spree pipe :D
abreen89
Post by abreen89 »
motomech wrote:Wouldn't work on these stock mufflers.
u just drill a hole??????
motomech
Post by motomech »
All the way though the two chambers inside the the muffler[It's really not a "pipe"].
I used a big two-handed drill motor.
