1986 Spree will not start
Posted: Fri Sep 07, 2012 5:28 pm
So my spree was turning on fine but it would not idle. i took the carb off cleaned it and it ran like a champ... for a day. the next morning it would not start. i took it apart again and the only thing i noticed was that the bystarter needle was hanging extra low. i believe if its cold it should be tight and the needle should be up not loose right? could this cause it not to start? any help would be much appreciated. i need this bad boy to get around campus so i really need to fix it.
