86 aero near 35mph and shuts off?
Posted: Sun Sep 09, 2012 11:59 pm
by jeph
Hi, i recently bought a 86 honda aero 50 off craigslist for 150 with bad rings. I replaced the rings and it fired up first try, im having a problem when i run wide open throttle around 30ish mph it feels like someone turned the key off and then i let off the throttle and it turns back on.
what could it be? it was missing intake tube and air box when i got it would that cause that? too much air.
also i know this is a newb question and i tried searching, how do i check the crankcase oil level? never had a 2 stroke before
thanks!
Re: 86 aero near 35mph and shuts off?
Posted: Mon Sep 10, 2012 4:25 am
by stucinthe80z
you might ask pappa bear or mousewheels .
Posted: Mon Sep 10, 2012 6:03 pm
by Pete M
There is no crankcase oil level. You have a fuel tank and an oil tank. A 2 stroke mixes the fuel and oil as it is sucked into the crankcase thus lubricateing the internal components. If you used premix you would not have an oil tank and mix the oil with the fuel.
Posted: Mon Sep 10, 2012 6:13 pm
by Dio89Elite
Perhaps he meant transmission oil level?
Please download your manual. I think this might be the link for it.
viewtopic.php?f=11&t=681
Section 3-4 shows how to check your transmission case oil level.
Posted: Tue Sep 11, 2012 1:33 am
by dun rite
did you put on an air box and intake tube? If not the motor will run lean and hot, possibly why it needed new rings. The right quantity of air. fuel and oil is essential for longevity.
Posted: Tue Sep 11, 2012 2:14 am
by GSX1400
Dio89Elite wrote:Perhaps he meant transmission oil level?
Honda doesn't recommend any time/distance changing intervals for the oil in the transmission???
Posted: Tue Sep 11, 2012 4:25 pm
by jeph
dun rite wrote:did you put on an air box and intake tube? If not the motor will run lean and hot, possibly why it needed new rings. The right quantity of air. fuel and oil is essential for longevity.
okay ill have to order a airbox and filter then because my scooter diddnt come with one and used scooter parts is hard to find around here lol.
is there a aftermarket filter on ebay that is equal to the oem box/filter setup?
also the guy i got it from said he rebuilt the carb and cleaned it out mabey he adjusted the air/fuel mix screw wrong?
Posted: Tue Sep 11, 2012 6:45 pm
by martynkim
If you actually bring the bike over when you come over I might be able to help.
Posted: Tue Sep 11, 2012 8:41 pm
by jeph
alright cool i send you a text when i put the bike back together should be tomarrow.
