66cc bbk w/stock head and pg short, jets?
anybody ever had a similar setup and what size jets would be good to start with?
- tazland001
Re: 66cc bbk w/stock head and pg short, jets?
Stock carb? If it is stock carb a 100 should be a good place to start. dont forget to do plug chops
taz
Taz
taz
Taz
oops sorry forgot to mention that im using a 28 carb, thnx, just removed the stock carb and pipe.
A 28 may prove difficult to tune with a 66cc engine. Flash II was a 65cc AF05 and 24 was as big as it could take. Not saying it can't be done, but maybe a 21 or 24 would run better.
yea i would rather use a 24 but i already had the 28 on the side.
currently running a 45 pilot one turn out and 140 main needle jet second from top. trying to make the carb sweat, not happening.
Swapped to 48 pilot and 1 1/2 turns out.
