1986 honda spree lights
Posted: Tue Oct 09, 2012 5:31 pm
by mauricio328
so i just fixed my honda spree scooter. replaced the piston rings. it starts just fine, but the head light and dash light will not turn on. all the other lights turn on with the battery connected, but without the battery no lights work. does anyone know why my head light and dash lights do not work. the lights used to work without the battery but now only the tail light and turn signals work when connected to the battery.
Re: 1986 honda spree lights
Posted: Tue Oct 09, 2012 6:59 pm
by abreen89
mauricio328 wrote:so i just fixed my honda spree scooter. replaced the piston rings. it starts just fine, but the head light and dash light will not turn on. all the other lights turn on with the battery connected, but without the battery no lights work. does anyone know why my head light and dash lights do not work. the lights used to work without the battery but now only the tail light and turn signals work when connected to the battery.
headlight and dash lights run of the stator so your engine has too be running for them to come on. Tail light and blinkers run off the battery.
Posted: Tue Oct 09, 2012 8:08 pm
by martynkim
mauricio328 wrote: it starts just fine, but the head light and dash light will not turn on.
Posted: Tue Oct 09, 2012 8:37 pm
by abreen89
martynkim wrote:mauricio328 wrote: it starts just fine, but the head light and dash light will not turn on.
missed that
.... I would check and make sure the wires are plugged in correctly and while your at it check the bulbs.
Posted: Tue Oct 09, 2012 11:24 pm
by mauricio328
Bulbs are all fine. Could it be a loose wire?
Posted: Wed Oct 10, 2012 12:43 am
by abreen89
mauricio328 wrote:Bulbs are all fine. Could it be a loose wire?
yes chase the wires and make sure they are all plugged in. if you checked the headlight bulb you should have been looking at the wires for it aswelll.
