9:1 gears set
micbergsma
9:1 gears set
Post by micbergsma »
9 to 1 gears set
http://www.ebay.com/itm/Honda-Elite-S-S ... e6&vxp=mtr
is that good one? I have 2001 honda elite 50 sr the black one. af16 engine...
is it ok to use 9:1 gears set for 50cc stock and 75cc kit too? I have 75cc kit I will put it on later...
Scooter videos on YouTube: http://bit.ly/2fK6kHJ
Website: http://bit.ly/2gvBRyI - Scooter IG: http://bit.ly/2fB8gay
micbergsma
Re: 9:1 gears set
that's me on my elite - all stock, went 40mph on the curve it was fun!
that's me!
that's me!
Re: 9:1 gears set
9:1 is pretty good on a stock block if it's producing good power. Mine went 49 with ZERO Engine mods, only the gears and a big variator and tire. Once you big-bore, the 9s will be a little short. You'll regain faster-than-stock take-off but it won't increase your speed very much unless the Big-Bore can rev higher than stock. At that point, you may want to swap again for 8.44s or whatever your riding needs and engine power dictate.
Carnie
9:1 gears set
Post by Carnie »
You can put them on with the stock bore and they will do fine but it won't be very whippy on acceleration. As for with the kit, you will probably be fine to use them but depending on the kit, you may want something a little taller. Don't forget to upjet!
1987 Spree
1994 Elite SR
CG Elite
Re: 9:1 gears set
Post by CG Elite »
Am I wrong that these will fit in a af50e motor with some shimming?
Re: 9:1 gears set
Post by eliteguy50 »
CG Elite wrote:Am I wrong that these will fit in a af50e motor with some shimming?
Yes, that is assumption is wrong.
devenex
Re: 9:1 gears set
Post by devenex »
You are wrong about that. Read this to see whats really needed:
http://www.hondaspree.net/phpBB3/viewto ... =8&t=11792
1986 Spree w/ '87 SE50 motor
