Stage 6 Intake Mani Question
Posted: Fri Oct 19, 2012 12:54 am
by Trafficjamz
What carbs are compatible with the stage 6 intake?
The angle is different from the CT chrome, and causes OKO carbs to not fit correctly. :crazy:
Re: Stage 6 Intake Mani Question
Posted: Fri Oct 19, 2012 10:00 am
by LMH
The mikunis and delorto style fit it from what I remember, it sits kind of close to the block if I remember right. I think theres an adapter for the Keihen / OKO style carbs if the one you have is too small in diameter also.
Posted: Fri Oct 19, 2012 10:04 am
by bradthreee
I think Sanjuro was running a Mikuni TM24
Posted: Fri Oct 19, 2012 10:22 am
by bakaracer
Trafficjamz wrote:What carbs are compatible with the stage 6 intake?
What makes it not fit correctly? That mani is a copy of the krs small.
Posted: Thu Oct 25, 2012 1:06 pm
by S4Patrick
This will work for ya:
http://www.drowsports.com/product/49/En ... Stage6_PWK
Been running a Stage 6 intake mani with a 21mm OKO carb mated to it with no problems for over 2 years now....
Pretty sure it's the 30mm you want.
Hope this helps ya Traffic!
:thumbwink:
Posted: Fri Oct 26, 2012 7:51 pm
by Trafficjamz
I will take some pictures tonight to show how it does not fit.
