My rear tire is a Bridgestone ecopia ep70r. It still has good tread but can't find info on it.
Just got a Michelin S1 for the front and wonder if I should get the same for the rear?
Thanks
Tire info
Re: Tire info
Just did extensive research for tires and did learn from some experts, if possible keeping the same tread pattern is best for all apparent reasons - traction/control/wear/etc.CG Elite wrote:My rear tire is a Bridgestone ecopia ep70r. It still has good tread but can't find info on it.
Thanks
So if they make the Michelin for the rear... might be your best bet...
'86 Aero 50 (NB50)
'01 Yamaha Jog Nextzone
Re: Tire info
Thanks for the input. I have read good things about the S1.
