Page 1 of 2
Pully Mod (not speed)
Posted: Wed Jun 14, 2006 7:47 pm
by Farfignugin
Ok, srry bout the subject but i didnt know how to word it.
Hopefully everyone knows about the pully mod and how u can shave some off the pully to gain some speed...BUT...I was wondering if (and how I would go about doing it) instead of shaving some off the pully, if I could put a washer between them in order to gain low-end speed (I live in a very hilly area and am more worried about gaining speed than having it).
If this is at all possible please reply with your suggestions on how to do it, and if anyone knows about how much top speed I would loose by doing so.
Thanks all in advance!
Posted: Thu Jun 15, 2006 9:46 am
by noiseguy
That should work fine, just use thin washers. You're looking to add about .03", which is about 1/32". Most washers are 1/16", and too thick, I think.
Watch the back part of the belt, that it stays inside the clutch halves. You should get better take off this way. You get higher RPM engagement since the clutch is now turning slower compared to the engine, and the Spree should have more torque at the higher RPM. I'm guessing that you'll loose 2-5 MPH on topend.
One other guy tried this and it didn't work, I'm guessing that he was using overly thick washers. This area is really sensitive to changes.
Posted: Thu Jun 15, 2006 10:33 am
by Farfignugin
Is that it? Kewl....so all i have to do is take off the pully (at the engine) and put a thin washer inbetween the pully halves?
Thanks! should help out a lot around where i live with all the hills
Posted: Thu Jun 15, 2006 3:00 pm
by Farfignugin
well, i lucked out. it worked! great takeoff along with good hill accell/speed. Thanks for your advice noiseguy. although...now i think i should try and find and even colder running plug for it since now it runs at higher rpm longer...any thoughts?
thanks again
Posted: Thu Jun 15, 2006 3:56 pm
by noiseguy
Yes on colder plug. What's your top speed now?
Posted: Thu Jun 15, 2006 4:02 pm
by Farfignugin
seems to top out more around 30 rather than 35 (although instead of .3 inch i found a .4).
Where could I get a colder plug? (other than the BPR8HS (or what I use: Champion QL78YC equivallent))
Posted: Thu Jun 15, 2006 5:22 pm
by Farfignugin
actually, it runs fine if not better than before!
tops out maybe around 32-33mph...but accelorates like crazy, even up hills!
best thing is, what i could do before at full throttle (on a flat) i can now do at 1/4-1/2 throttle.
Great modification for driving around in hilly areas.
Posted: Thu Jun 15, 2006 11:29 pm
by darat
thats good to hear
Posted: Mon Jun 19, 2006 10:45 pm
by kurremkarm
I wish someone would take some pics of the pulleys and how to mod them. When you take some off the pulley do u sand it or what?
Posted: Wed Oct 11, 2006 11:20 am
by Kikwear
Farfignugin wrote:well, i lucked out. it worked! great takeoff along with good hill accell/speed. Thanks for your advice noiseguy. although...now i think i should try and find and even colder running plug for it since now it runs at higher rpm longer...any thoughts?
thanks again
What size washer did you end up using?
a little more info
Posted: Thu Jun 28, 2007 6:40 pm
by malaka
i was wondering if i could get some more info on what you did. i am looking to do the same thing to a spree i am about to prchase, im more interested in getting more low end then hitting 40mph. any advice you could give me will help a ton.
Posted: Thu Jun 28, 2007 10:32 pm
by Farfignugin
when I took the front pully off of the shaft, there was a thin washer behind it (about .03" i think thick). I used that washer in between the pully halves and then put it back together as normal. The scooter will be able to idle a little higher without moving the back tire; good improvement on acceleration; and about 3 mph lost at top end.
Posted: Thu Jun 28, 2007 10:41 pm
by noiseguy
Dude, get that washer back where it belongs or buy another one to replace it. You need that washer in there or you will ruin the crank!
This is a good tip though, and those washers are the right thickness to do this. Good for offroading!
Posted: Fri Jun 29, 2007 6:23 pm
by Farfignugin
why will it ruin the crank?
Posted: Sat Jun 30, 2007 12:39 am
by noiseguy
Not exactly sure... I think that the washer keeps the crank and pulley half turning together, since it's made of a softer material. I've seen the damage, though, and it's not easy to fix.
