completely redid my 89 elite again (:
7m-iata
Post by 7m-iata »
Finally broke down and painted EVERYTHING as well as replaced the engine and reconfigured the suspension and all that jazz d:. Well here she is in all her glory I have a 1/2 gal gas tank, 73cc bore kit with "matched" pipe. All electronics and batt relocated inside the front cover 1e40qmb (minarelli/jog clone) engine. Only thing I have left to do is a little tuning and my rear lights mounted (L.E.Ds) YES it DOES have rear brakes I have the cable off right now I was debating running more of a ruckus style bar setup still havent decided yet... opinions?
deuce217
Re: completely redid my 89 elite again (:
Post by deuce217 »
Is that a chinese engine/ clone? If so I think the cover needs to be on that back to help support the clutch shaft. Or at least on my brother in laws it was needed. You might take the belt off and see how much side play there is on that shaft.
The ride looks good :thumbwink:
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
7m-iata
Post by 7m-iata »
It is a chinese clone thanks for that might have to come up with an idea on that one. There isn't any play so I didn't think the bearing in the cover was all that necessary I'll look into what I can do with the case that'll still look alright.
sum-azn-kid
Post by sum-azn-kid »
I like the look with the panels on too bad you dont have the rear panels too.
zuma 125-sold
Ninja 250r-totaled
7m-iata
Post by 7m-iata »
yeah I though about getting a set, but I can't find any at a price that I like since it not something I NEED more of something I WANT lol
sum-azn-kid
How hard was it to swap in the jog motor? What kind of mods did you do to the wire harness?
zuma 125-sold
Ninja 250r-totaled
7m-iata
Post by 7m-iata »
Wire harness is pretty much plug n play just match up the colors. I had to build mounts since the jog engine is top mount engine, I fabrcate for a living though it took about an hour to cut off the old mount from the frame make and weld on the tabs.
Downsouthdio
Post by Downsouthdio »
Bro thats nice man.. Where in florida do you live..?
Honda super dio
Corsa
26mm
Sparrow
7m-iata
Post by 7m-iata »
I'm in sarasota its about 30 min south of tampa. Thanks it's always nice to get compliments (:
Pismobear
Post by Pismobear »
It looks good all layed out like that.
You gotta stop, hey, whats that sound? Everybody look.. Ah whatever.
85 Honda Aero50
evilone
Post by evilone »
Slick, nice work.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
7m-iata
Post by 7m-iata »
thanks, now if only it would run as good as it looks lol
Eight pack
Post by Eight pack »
d*** that looks sick. I wanna do my spree like that now
7m-iata
Post by 7m-iata »
It'd be kool to see some more modded no ruckus scoots out there go for it!!
7m-iata
Post by 7m-iata »
Installed my lights and new wheel/tire today the lights are all wired up and blinking as they should nicely tucked under the seat (:
