Pretty sure thats the end.
SpamMusubi4Life
Post by SpamMusubi4Life »
Well the long distance travel everyday has done some numbers on my Corsa and destroyed my piston. It doesnt start probably due to the piston rings being stuck. no compression. To top it off, I went all He-Man when putting everything back together, the long bolts thats hold the bore to the block, i stripped one. F U C K M Y L I F E!! Not sure if it would be wise to run it with only 3 bolts but i dont have any extra cash to pick up another dio block. can it be mended? If so I'll just pick another piston n rings.
'85 Honda Aero AF16 Corsa
808
ALL
DAY
kingkamehameha
Re: Pretty sure thats the end.
Post by kingkamehameha »
Get a machine shop to put a time sert into the tripped hole
SpamMusubi4Life
What's that?
808
ALL
DAY
7m-iata
Post by 7m-iata »
Drill the block larger tap it the right size go to home depot and get a thread insert red thread lock it in place.
kingkamehameha wrote:Get a machine shop to put a time sert into the tripped hole
SpamMusubi4Life wrote:What's that?
Must be what is known by most as "heli-coil".... :hi:
7m-iata wrote:Drill the block larger tap it the right size go to home depot and get a thread insert red thread lock it in place.
Second: Drill the block larger. (Heli-Coil kits include drill bit and tap)
Third: Tap it the right size.
FIRST: (determine the size of threads) Go to Home Depot (or auto-parts store) and get a thread insert. (the next size larger)
Fourth: Red thread lock it in place. (Loctite brand)
SpamMusubi4Life
Got it. Thanks doods.
808
ALL
DAY
veedubh20
Post by veedubh20 »
helicoil is pos!
get time sert look on youtubes
http://www.timesert.com/
This is a link to the TimeSert being recommended.... :wink:
I am sorry to be so far behind modern technology.
I have used Heli-coils with 100% success for 30+ years.
Time Sert may be better for your application.
SpamMusubi4Life
Wow! That's exactly what I had in mind. Where would I be without you guys.
Probably selling it on Craigslist.
808
ALL
DAY
