I have a leaky S50 oil pump that needs replacing,
Can i put in the oil pump form an SA50? I have access to one cheap.
SA50 VS SE50 oil pump differences?
Re: SA50 VS SE50 oil pump differences?
Looks like they are both AF05E engines so the answer isnYES
I am a little disappointed this got zero traction on the board
I think I may have the same problem on my 2001 Elite...an SA50......how did the replacement go??
SA 50 and SE 50 are model codes, and do NOT designate what engine you have. The SE model only lasted 1 year in the US (1987) but its engine - the 05 - survived in the SA50 until 1993. After that the SA50 scooters were fitted with the AF16 engine. Pump swappability between the 05 and the 16 is uncertain.
88-93 sa50 and the 87 se50 have the afo5 engine whereas the 94-01 sa50 has the af16 engine. sa50p or se50p oil pumps dont produce the same output as the unrestricted version. as far as compatibility not exactly sure but i imagine if its a 94-01 you would just swap the shaft but dont quote me
on the 94- 01 you can use a sym oil pump just swap the shaft, don't know about the older models.
