speed variator pully
mikehailwood
Post by mikehailwood »
I was told that this 2000 Elite has had a "speed variator pully" installed. What is this?
Mike
Farfignugin
Post by Farfignugin »
it's like a CVT (Continuously Varying Transmission). As your engine revs, the pullys open or close depending on belt speed thus changing the ratio from engine to tire.
mikehailwood
Does this device effect the the bottom end or the top end of the speed range?
Mike
Farfignugin
both, its pretty much like an absolutely seemless automatic transmission
Caladan16
Post by Caladan16 »
In case you haven't seen this, here's a link to a great explanation of the function of the variator.
http://vossmotocycles.com/variator.html
1987 SE50 Elite S
stillspeeding
Post by stillspeeding »
do you mean a high-speed pulley, this is part of increasing the engine speed or taking off the restrictions that came from the factory.
Can't afford speed then stay away from it!
