I got ONE more elite E but straight bone stock.
N I read the engine code on it n it read AF05e n I kno and 87 se50 is also an AF05. I was wondering if there is any different specs and if parts are inter changeable? Or if the SE50 BLOCK will mount up to the elite E frame with no mods. Or maybe jus the gear cover was changed out? Or any ect helpfull things you guy cud tell me wud b great. So please lmk
SE50 AND SB50 af05?
Re: SE50 AND SB50 af05?
Whole different engine. The one in the se50 is a true cvt trans. The elite e is not. Plus the elite e motor spins backwards. If trying to swap the se50 motor in, it would be the same way as swapping in a dio
So the se50 is an af05 right? And the block I got on this eliteE says af05e. Do u think jus the gear cover got switched out? Kuz I kno the block I have on it now is the stock one
K nvm I talked to one of my buddies that knew. Thanks
