SIP-Scootershop.com Malossi cast iron cylinder kit specs
bonesv
Post by bonesv »
I copied this from sip-scootershop to reveal the specs as advertised on their site for Malossi Cyl. kit #31-7200 for anyone interested. I suppose you could also go to red eft performance and ask Keith if he has any info as he sells these kits at a great price! Not one word has been changed from this "copy". http://www.sip-scootershop.com/en/produ ... c+_m317200
"Pictures may look different
Racing Cylinder MALOSSI 72cc
for HONDA/KYMCO/ITTECO/SANG
YANG 50cc 2-Stroke AC
cast iron,
2 piston ring(s), pin 12mm,
w cylinder head, ├ÿ 47,0mm
68cc out of the high tech tuning company, MALOSSI puts a lot of bite in your total rpm range. Thermodynamic performance leads to optimal ?every day useÔÇ£, making it easy to move up to the 68 cubic class. Size does matter!
Iron cast / 47 mm bore / 9.500-10.700 rpmÔÇÿs
Pepped up outlet, optimized valve timing, higher compression. Periphery, like exhaust, carburetor and transmission can and should be modified. Maximal speeds up to ca. 95 km/h possible. Not road legal."
kingkamehameha
Re: SIP-Scootershop.com Malossi cast iron cylinder kit specs
Post by kingkamehameha »
Why dont you read the little yellow paper that comes with the fkn bore it tells you right on there that it makes peak power at 8k dont believe what some salesman tries to tell you. Thats what the manufacturer themselves rate the bore at! They are advertising the rpms for the d*** mhr on there not the cast iron.
Downsouthdio
Post by Downsouthdio »
Actually , malossi claims 10,800-11,800 rpms from the mhr
Honda super dio
Corsa
26mm
Sparrow
kingkamehameha
Downsouthdio wrote:Actually , malossi claims 10,800-11,800 rpms from the mhr
Mabey for a jog
Red Eft Performance
Post by Red Eft Performance »
Straight from the technicians at Malossi
cast bore 31-7200 8500-9500rpm
MHR 31-8475 9500-10500rpm
Keep in mind these numbers are for ideal peak power. These bores can and will turn a little more pending on setup.
Also keep in mind your probably not going to get peak power at these points with a less than ideal setup.
Contrary to what most believe on this forum the pipe options for the af16 are crap. Unless you want to shell out some money for something exotic.
Red Eft Performance
View products click => Here
kingkamehameha
Red Eft Performance wrote:Straight from the technicians at Malossi
That ends this discussion now we can move on. Heard it from the man himself. The cast iron simply cant rev up to what you guys are claiming. Unless you have baka or tru72 do your block ports and agressive jug porting. They are the only two i know with high end dental tools and diamond bits with 90 degree angles
kingkamehameha
The purpose of the street bore is a long lifespan. You get half the life span on the mhr because of the high revs. You dont need 10k for a dd hes not trying to go 70 all time
kingkamehameha
And a pg short putting a cast iron up to over 10k is unheard of
Downsouthdio
According to my trail tech vapor.. I was able to touch 12,220 rpm's today.. My max temp was 311 though.. Whats high temps 350 around there?
Honda super dio
Corsa
26mm
Sparrow
kingkamehameha
Downsouthdio wrote:According to my trail tech vapor.. I was able to touch 12,220 rpm's today.. My max temp was 311 though.. Whats high temps 350 around there?
Not surprised your able to keep low temps with the aluminum bore its a cooler running bore than the cast irons. 350 is good temps still but once it starts climbing past that then i wouldnt push it. 325 is considered running cool. Whats your WOT temps for a long pull
Downsouthdio
Havent held it too long wot but i will see.. So 325 is cool so then i should be fine
Honda super dio
Corsa
26mm
Sparrow
