50mm wit 72 bore?
PurpleMonsta808
50mm wit 72 bore?
Post by PurpleMonsta808 »
whats the cons wen u use a 50mm stroker crank with a 72 polini bore?
veedubh20
Re: 50mm wit 72 bore?
Post by veedubh20 »
not going to work...............................................
no ask more dumb questions.. if you reading this and you wasting time..
vette76
Post by vette76 »
you need a stroker bore. it has a taller height to make up for the increase in STROKE.
87' spree (SOLD
12' wrx
bakaracer
Post by bakaracer »
PurpleMonsta808 wrote:whats the cons wen u use a 50mm stroker crank with a 72 polini bore?
Port duration is going to be waaaayy to off. If its a corsa, the duration is somewhat high already with a stock stroke. That's why that bore out the box can rev to 11k .
