nb50 vision/aero not starting
uk-visionsa50
Post by uk-visionsa50 »
recently did a load of work on my scooter, changed spark plug,cleaned carb,new fuel lines,new oil lines, cleaned out oil and fuel tanks and filled them up with new fuel and oil, charged battery, new air filter element etc etc, i come to start it this morning and for some reason it just wont start up, it started up fine 2 days ago, the engine is turning over but just will not fire up. as i knew the great bear would say compression before anything so checked that its at 124psi, ive got a good strong spark, ive got fuel going in, the muffler was cleaned out so i know its not that, the intakes all fine, everything id normally check is all good, but it will not start. any ideas on what could be up ?
any help much appreciated
thanks
Re: nb50 vision/aero not starting
Post by swimmingfree »
is the plug wet or dry??
uk-visionsa50
the plug is wet
dry the plug ..roll the motor over with out the plug and let it dry out then try it again..
you flooded it
uk-visionsa50
ok thanks, ill try it tommorrow and post back :)
uk-visionsa50
didnt work at all, its just turning over wont fire up still :sad:
WeeMan
Post by WeeMan »
Hi There,
Mine did this a few months ago. I presume you took the carb off to clean it? I would check the reed valve. I fitted a malossi one and it was slightly open which created flooding. I put the old one back on and it fired first time. Worth a look. Top tip dont fit malossi reed valves in my opinion as they are a pain is the bum.
uk-visionsa50
yeah carbs been cleaned, thanks for that ill take a look now.
turtle13
Post by turtle13 »
Check the bystarter the on the carb too.
'62 125cc Honda cub
uk-visionsa50
nothings working, gonna get another kickstart and try kicking it over, i have a sneaking suspision my electric start is just playing up
swflcarl
Post by swflcarl »
Thought you said it was turning over... am confused? Is there fuel in bowl?
'86 Spree - Gone
'86 Spree - Gone
'85 Aero 50 - Gone
'94 Elite SR - Gone
'96 Elite SR - Gone
'01 Elite S
'85 Gyro - Its Alive
uk-visionsa50
when i said turning over i meant i could hear the starter motor working but, borrowed a kickstart from redvisionmonster today and after about 20 kicks it fired up and ran fine, after that it started first kick, it just wont fire up off the electric start. so i need to get a kickstart of my own now.
swflcarl
Post by swflcarl »
Okay... sounds like the bystater to me. Pull it and apply 12 volts... see if it moves out. This is called the enrichment circuit used to feed extra fuel during a cold start more or less. Can be had for about $20 online... best regards!
'86 Spree - Gone
'86 Spree - Gone
'85 Aero 50 - Gone
'94 Elite SR - Gone
'96 Elite SR - Gone
'01 Elite S
uk-visionsa50
i will do after this snow clears hate this bloody weather !!
couple inches of snow and the whole country comes to a hault !
:twisted:
uk-visionsa50
ok, ive had the bystarter off and it was dead, nothing happened whatsoever, picked up one from honda dealership, put it on, not tried starting it yet as im refurbishing a few parts first.
