Clicking noise coming from engine
I just recently installed a polini contessa in my dd50 and it started making a clicking noise from the engine area. Has anyone come across this problem before?
SYM DD50 w/AF16
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
Polini 3G Adjustable Clutch
8 to 1 gearing
TT Vapor
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
8 to 1 gearing
TT Vapor
Re: Clicking noise coming from engine
Raymz808 wrote:I just recently installed a polini contessa and it started making a clicking noise from the engine area. Has anyone come across this problem before?
...only the ones that goofed something.....bummer for ya
Yeah bummers! Got around 200+ miles on the bore then clicking started. Just trying to find out if it could be the rings or something really serious. Runs great except for the clicking.
SYM DD50 w/AF16
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
8 to 1 gearing
TT Vapor
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
8 to 1 gearing
TT Vapor
- paulpauly7
remove the head and look for damage
I took the head and cylinder off and everything looks good. Piston looks to be in really good shape too.
SYM DD50 w/AF16
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
8 to 1 gearing
TT Vapor
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
8 to 1 gearing
TT Vapor
- swimmingfree
do a compression test it should tell if it in good shape..
That is the next thing I was planning to do. I'll also put in a new wrist pin bearing just to see if that helps. Thanks for the reply!
SYM DD50 w/AF16
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
8 to 1 gearing
TT Vapor
Malossi MHR 72CC
PG Long, YMS V8
21mm OKO
CT Chrome
Keli pulley
SEF ramp
8 to 1 gearing
TT Vapor
