94 elite sr, kick start has a LOT of resistance! help!
walks0nwater
Post by walks0nwater »
alright so my brother was going to use my scooter to ride up to the store he kept kicking it constantly wouldnt start. so eventually it was very hard to kick. the electric start does the same thing it moves the crank very slowly while trying to get it started..any ideas?
dun rite
Re: 94 elite sr, kick start has a LOT of resistance! help!
Post by dun rite »
pull the spark plug and kick it over and see if it gets better.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
walks0nwater
alright i tried doing that..it kicks over but comes up slowly with the spark plug out. soon as i put it back in doing the same thing. could my engine be flooded?
dun rite
Post by dun rite »
If your saying it kicks fine but returns slowly then you need to clean the kick start assy. If fuel oil mix comes out of the spark plug hole when you kick it, then yes it's flooded. If no fluid comes out when kicked then your exhaust could be plugged, either barbecue the muffler (check the wiki for instructions) or you may need to clean the carbon from the exhaust port. Or could just be gummed up or broken kick start assy
arreche air filter
v8 pipe
stock gears
walks0nwater
well the engine is definitely flooded, quite a bit of liquid comes out. also ive de-carbonized the muffler pretty recently. so i should be good on that. i think the kick start assembly might be broken aswell as the engine flooded. how would i go about un-flooding an engine? never done it before S:
paulpauly7
Post by paulpauly7 »
take off intake manifold and tip the engine on it side to drain it out
