From Jim's Honda Spree Repair website
1. Remove both rear frame covers.
2. Disconnect the oil inlet line at the oil pump and allow the oil to drain into a clean container.
3. Loosen the tube clip and disconnect the oil tube joint under the oil tank.
4. Remove the oil strainer.
5. Clean the oil strainer with compressed air.
6. Installation of the oil strainer is the reverse of removal.
7. Fill oil tank with the recommended oil up to the proper level.
8. Bleed air from the oil pump and oil line.
How to clean oil strainer
Moderator: FAQ Moderator
83 Suzuki GS450E - Sold
Spree Repair Guide
Spree Repair Guide
