Battery Tip / short bolts (66six)
Batteries are always a problem .
Here is a dumb tip .
On some batteries the screw will not reach the battery bolt terminal once the connector is on .
Here is what I do too solve the problem .
Take a small piece of foam cut it a little larger than the terminal hole .
stick it and the nut / lug into the terminal hole / The foam will hold the nut in place .
No more messing around trying to catch the threads in the nut or having them fall out if you tilt the battery .
What could be simpler than this ?
all you need  sizzor  / foam / nuts & bolts  and a battery .
The foam holding the nut in place .
shadow622
Re: Battery Tip / short bolts (66six)
Post by shadow622 »
Nifty idea.
patthesoundguy
Post by patthesoundguy »
Brilliant completely brilliant thanks for sharing :-)
66SIX wrote:What could be simpler than this ?
My idea of using shrink tube or a drinking straw may not be simpler, but less likely to attract and hold moisture....besides, I use all my foam rubber to stuff sock-monkeys.... :hi:
Drinking straws do hold moisture thats what they are made to do ...
The shrink tube would shrink in Vegas summers 125 degrees.
Straws should be used to consume Myers & coke or foo foo drinks in Mexico .
You say you can't find foam it's everywhere you just need to look ...
I am using a straw in Mexico to retain moisture . Not to hold  my nuts in a battery .
Mike  this is what straws are used for / retaining moisture .
I think I found a good source for finding foam
Johnniespeed
Post by Johnniespeed »
I'm going on a foam source finding mission.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
patthesoundguy
Your local dollar store will probably have foam. Sometimes they have foam floor tiles on the kids toy section, or in the craft section
