I know it's not all plug and play, so after reading I see you need to splice the stator wire. Where exactly does it go? Does anyone have a picture or diagram to show the swap wiring?
Thanks
Spree with af16 wiring question
STLSpreedio
- swimmingfree
Re: Spree with af16 wiring question
if i remeber right it is a plus and play just mach the color and you may have a exter green ..
STLSpreedio
Everything is matched up. Without any electronics connected, it runs perfect.once I hook up everything to the stator, it barely wants to run, turn the lights on bright and it dies. What could be causing this issue? Everything worked before on the spree.
- swimmingfree
r.p.m. to low...
- Trafficjamz
is the block grounded to the frame?
STLSpreedio
Will post an update on everything replied soon. The scoot is at my buddy's place. Thanks to all that replied. Also, the headlight got nuclear bright when it did run with everything hooked up.
