elite project
slow elite kw
elite project
Post by slow elite kw »
My 90cc elite with a 30mm carb and a 32mm exhaust almost done
patthesoundguy
Re: elite project
Post by patthesoundguy »
Love the paint job great colour scheme :-) but there is a possibility that you may have trouble using a 30mm carb on a 90cc it might be a little big. Might be fine with the big pipe though.
inkerb2b
Re: elite project
Post by inkerb2b »
Awesome
slow elite kw
Re: elite project
I also have a 24mm should i use that one instead
Re: elite project
What cylinder and crank? 30mm will be tricky to tune for rideability, but 26 or 28 will be faster than 24 on top. Treatland and at least one Forum member can sell you a 28 for around $75. You can sell yours for around$50 a pop used.
slow elite kw
Re: elite project
Stock crank and 50mm bore kit is going to b on e85 thats why im runing a 30mm e85 requires alot of air and fuel
patthesoundguy
Re: elite project
E85 prob won't require the extra air, its the extra fuel that will be needed. You have both carbs so if the 30 turns out not to work you can always swap out to the 24. As long as the carb is jetted right so it gets enough fuel and you dont seize anything you've got nothing to loose but try the 30mm and see what happens. If it were me I would run the 24mm and get it dialed in for break in and then then try the 30mm. Give it a go and let us know how it works, E85 is kind of a new frontier and any info at all on what works is awesome and I'm sure the rest of us will benefit.
slow elite kw
Re: elite project
My dayli driven is a 50mm with a 44mm crank 150 compretion is got a 28mm carb on e85 with some 18/39 gears it does 75mph but the only problem that i had with the e85 is that it eat my float in the tank but the engine was runing alot better and cooler on e85 i had a 66pilot with a 190 main but i have to travel 100 miles to get e85 thats why now is bsck to 93octaine but this one will b e85 i just cant run a float on the tank lol it mekt it like butter lol
Re: elite project
I wonder if the fuel gauge sender and the carb float might be made of the same material? Hmm...
slow elite kw
Re: elite project
At first i tought it was the carb float i keep taking it of and it will still be nasty untill i look into my gas tank lol nasty s*** but man the gas millage suks hahahaaa
slow elite kw
Re: elite project
Gas tank under seat
slow elite kw
Re: elite project
Did a complete wire tuck even the ignition key is under the seat it looks like a ruckus
Elite project
Elite project
maddog
Re: elite project
Post by maddog »
As you know you should match the crank to the bore, so your crank seals will blow real fast :smile: btw mustard & black paint is hot, front shocks are needed....
slow elite kw
Re: elite project
Yea the shoks are on the way this one is a stock crank i just use a really thin base gasket to get more compression
