alloy drive face pros? cons?
- paulpauly7
looking at buying one if i get some sort of performance gain from it
Whats the pros and cons about these ?
Has anyone used one or are using one now?
- kingkamehameha
Re: alloy drive face pros? cons?
Lighter but prone to stripping and perhaps damaging crank splines. Alot of guys use them with no problem but I like to use a new oem honda one on my bikes
- paulpauly7
so being lighter it works like a lightened flywheel on a car leting the engine rev easyer less rotating mass
- kingkamehameha
Yuppaulpauly7 wrote:so being lighter it works like a lightened flywheel on a car leting the engine rev easyer less rotating mass
- paulpauly7
thank you for your input may just stick with oem as im gonna shim the front pully
could always lighten the stock face too-- ive used after market one's they only strip if your a meatball and use impacts on them lol
Not much for the front pulley but the stage-6 clutch setup will blow tour your mind
- Trafficjamz
Read more here ----- viewtopic.php?f=4&t=24696
Watch my video----- http://s751.photobucket.com/albums/xx15 ... EO0173.mp4
youll destroy that with a stroker
- Trafficjamz
Yeah I know.tru72 wrote:youll destroy that with a stroker
Drive faces,ramp plates, rollers, and belts all get destroyed from a 125cc stroker.
I never said what type stroker, you can't even find the old school parts i use
