Anyone ever considered or heard of a hydraulic variator?
Posted: Fri Mar 01, 2013 1:32 pm
This is absolutely theoretical, and I do not possess the machining and fabricating skills to do anything like this, but food for thought and good discussion.
Has anyone considered, thought about, or heard of using a hydraulic actuator to control variator movement?
I was thinking something like this:
http://www.ramclutches.com/zen-cart/ind ... ge&pID=678
It is your basic hydraulic throw out bearing. It could mount to the case behind the variator, custom machined variator, no rollers, roller sockets, ramp plate, or anything, just a surface for the bearing to fit to the variator.
The driver could control the hydraulics via left hand throttle equivalent, thumb slide (like ATV), or foot pedal.
Obviously a strong center spring is needed in the back, maybe a 2k or more, reinforced welds anyone?
Belt stretching is a concern, as you could exert quite a bit of pressure.
User would be in control of engine RPM, and belt movement through the sheaves instantaneously.
Just throwing out as a thought, again, as wheelman and Baka can attest....I am NO expert with scooters, can't even get mine do do what I want.....Just trying to see if this is an interesting topic on the board.
