Hello All, I have a retiree friend who wants a little more speed maybe 5-8 mph out of his 02 Yamaha Vino 4 stroke. Any quick tips to increase the takeoff without becoming too raucous?
Thanks, Ted
02 Yamaha Vino
02 Yamaha Vino
85 Iowa Spree
86 Spree Limited Edition
09 Nautilus "Seahorse" (homebuilt)
10 Nautilus "Seabrook" (homebuilt)[/color]
79 Honda Express
67 Harley~Davidson golf cart
79 Honda Express
Re: 02 Yamaha Vino
02 vino? is at a 50 cc?
Re: 02 Yamaha Vino
My mistake, the Vino is a 2 cycle. I have read about removing a washer between the variator clutch and grinding out the exhaust pipe restrictor. I was cautioned however that the washer removal may make the belt too tight to start. I also heard the vino has the same motor as the zuma, and a friend with one of the last 2 stroke zumas mentioned grinding a cam on the throttle so the plunger lifts fully. Sound correct?
85 Iowa Spree
79 Honda Express
79 Honda Express
Re: 02 Yamaha Vino
The motor is basically the same, some differences. Removing the washer helps. A chamber pipe will liven it up.
Re: 02 Yamaha Vino
I had a vino a while back. Removing the spacer in the front pulley helped a little (the washer was already removed from exhaust). The stock muffler is pretty restrictive, so pretty much anything aftermarket should give improvement.
Also replacing the stock 80/90's with 3.00" size tires really helps handling and ride quality, and should give a little upgear w/ no real loss of accel if you adjust the pulley weights down.
1986 Spree w/ '87 SE50 motor
