Monkey wheels???
Monkey wheels???
I have an 01 honda elite sr50 and want some new wheels. Does anyone know if the monkey wheels found in like eBay 10in x2.5in will fit my scooter. Also what kind of hub ill need to make it work and where I can get one.
Re: Monkey wheels???
http://standardfunctions.com/store/inde ... m-hub.html
use this to convert the rear and run a skinny rukus setup. The monkey is 4x91 and the ruckus is 4x140.. You could have the mokey wheel redrilled to 4x140 but then you would have 2 bolt patterns. Fronts you would need to convert to a Ruck or sym style setup and disc brakes would be easiest.
