Page 1 of 2
Blinker Issues
Posted: Tue Mar 19, 2013 9:31 pm
by wolf95
Hello,
I recently replaced my old rear stock turn signals with some after market ones, which are LED, however now they don't flash. I'm guessing it's the turn signal relay, but I'm not quite sure what would fix it, any ideas?
Re: Blinker Issues
Posted: Wed Mar 20, 2013 12:56 am
by patthesoundguy
You need to go get an electronic relay that only needs the resistance of one bulb or no resistance at all to flash. The relays in the scooters need the resistance of two bulbs to flash. The new relay should be available at most parts shops for cars for not a lot of money, I have one on my tractor cost me 6$ same as the one that will fit a spree or the like. If you can't get a relay to work you need to take a multimeter and measure the resistance of the original bulb and get two resisters of the same value and put them in line with each of the led lights.
Re: Blinker Issues
Posted: Sun Mar 24, 2013 10:16 pm
by wolf95
I added a resistor to the - side of the LEDs, however those dimmed and they still didn't blink, so I'm thinking of getting the relay, is there an easy way to tell where it is? Also did it plug right in, or did you have to rewire a few things?
Re: Blinker Issues
Posted: Sun Mar 24, 2013 10:21 pm
by patthesoundguy
Most of the scooters take a two prong relay. On the spree its in a rubber holder on the frame under the seat next to the regulator. Some scoots have them in the headlight area I think, like the 85 aero 80.
Re: Blinker Issues
Posted: Sun Mar 24, 2013 10:34 pm
by patthesoundguy
I'll tell you what, I'll borrow the electronic flasher from my tractor and try it on my spree with the rear lights disconnected, if the fronts flash which I know they will that will be a working flasher and I'll give you the part number from it if it has one so you can get one at the local parts store.
Re: Blinker Issues
Posted: Sun Mar 24, 2013 10:39 pm
by wolf95
Awesome, Thanks so much.
Re: Blinker Issues
Posted: Sun Mar 24, 2013 11:02 pm
by patthesoundguy
Here is the flasher I have,
http://www.princessauto.com/pal/product ... it-Flasher
I saw the same one on eBay for over $20 lol. You can see the number on the side in the picture. I bet is you show the that web page to the parts store they will have it. I'll try and test that in about two hours when I get home after my gig. Should only take a min or so. The scoter and tractor are right next to each other
Re: Blinker Issues
Posted: Sun Mar 24, 2013 11:22 pm
I've run a 2 pin "Blazer variable load flasher, FL552/536" from the local auto parts store.
It is an electronic flasher, and will flash fine with only 1 signal lamp.
Stock Honda flag terminals fit over the flasher. It's round so you'll have to mount it differently than OEM.
It is not an LED rated flasher. The flasher will not flash correctly with all signal lamps converted to LEDs.
Link to thread
Re: Blinker Issues
Posted: Sun Mar 24, 2013 11:27 pm
by patthesoundguy
As long as there is one incandescent bulb it should go. The flasher in the link will flash 2 tiny standard bulbs and 2 leds at a very wide voltage range, I run my tractor light on the gen only no battery and they flash at all but the lowest throttle. I'm betting that the blazer flasher is a standard item and the princess auto flasher is the same part.
Re: Blinker Issues
Posted: Mon Mar 25, 2013 12:46 am
by patthesoundguy
Confirmed works on one bulb. Ill dig out an led light tomorow and try it with that
Re: Blinker Issues
Posted: Mon Mar 25, 2013 1:18 am
by paulpauly7
i have a UNIZEN flasher unit it has a variable flasher speed and a option to play a tune kinda like what you hear when you open a musical christmas card haha .It plays tunes like london bridge is falling down , mary had a little lamb and so on theres like 10 different songs
Re: Blinker Issues
Posted: Mon Mar 25, 2013 6:07 am
by rawhead
Lol,
How about getting a lightbar from a state patrol car and the music box from an ice cream truck. :p
Re: Blinker Issues
Posted: Mon Mar 25, 2013 6:20 am
by vette76
http://www.superbrightleds.com/moreinfo ... r/193/841/
this is what i use in mine. works perfect. and dosent add a load like the band aid fixes.
Re: Blinker Issues
Posted: Mon Mar 25, 2013 9:16 am
by patthesoundguy
That's perfect thanks for posting that site, Im sure it will come in handy for lots of people
Re: Blinker Issues
Posted: Mon Apr 08, 2013 12:29 am
by wolf95
Got one of those electronic flashers. They work now, but the LEDs a little bit dim (I think it's a voltage-related issue though).
