valve set starter
Posted: Mon Mar 25, 2013 11:53 pm
by vspecter
Question is: Can I run without a ''valve set starter'' ?
Thanks!
Pascal
Re: valve set starter
Posted: Tue Mar 26, 2013 3:31 am
by PimpinSpree
* is a valve set starter?
Posted: Tue Mar 26, 2013 12:16 pm
"Valve set starter" is the description Honda uses in the parts fiche, for example the NQ50. Honda's NQ50 Service Manual uses the term 'Auto Bystarter' when referring to the same part.
Running with no bystarter will make the scooter run lean, it will create an air leak.
Posted: Tue Mar 26, 2013 6:46 pm
by patthesoundguy
There is a manual replacement for the by starter available, but why go with out any by starter or the like when they are so cheap.
Posted: Tue Mar 26, 2013 7:08 pm
by bushpigwillie
I am running with my bystarter overidden. I switched the internal spring to keep the internal needle closed. Don't run completely without as it will have an air leak.
Posted: Thu Mar 28, 2013 1:54 am
by vspecter
I just bought my Spree and the previous owner take the bystarter off and he puts some silicon
Posted: Fri Mar 29, 2013 9:44 am
by patthesoundguy
vspecter wrote:I just bought my Spree and the previous owner take the bystarter off and he puts some silicon
At least silicone is easy to remove and clean off to put a by starter on it, could have been JB Weld in there, yikes
