I am going to attempt to remove my carb on my 86 spree.
Not sure how the nut on top is removed, and the cable detached.
Would like suggestion from someone who has done it before, so I don't break something
Thanks
swimmingfreestevefishy11 wrote:Thanks for the reply.
I looked at the manual, and it does not clearly show the removal of the cable.
Do I just unscrew the top and pull it out?
The top nut seems loose, but does not unscrew easily.just unscrew
Is it attached to the slide inside somehow.?
Thanks
