Spree revs out on start up
killingspree1985
Post by killingspree1985 »
So I just rebuilt a 1985 spree new rings and piston and put everything back together went to fire it up and she roared..... Except it just revs out! So I killed it and re adjusted the carb and it did the same thing....so then I thought it was in my throttle cable ...nothing looked out of the norm and it did it again....could it be my carb? Did I do something wrong?? Any help is appreciated thanks
Re: Spree revs out on start up
Post by swimmingfree »
yes its the carb you havee the slide in wrong ... lol not the first time that happen...
ps
please delete your other post on here ....
Thanks swmmingfree :thumbwink:
Around here, you will find the same helpful folks in all forums. For this topic - please post once to Technical Help Forum as you also have done.
-- Spring time reminder --
Double posting and off-topic postings may get you a warning. Three warnings, and there is a time-out period.
