Wondering how my stock carb and airbox on my elite 00' af16 will run with a malossi bbk from red?
I'd like my build to be as follows:
Cast iron malossi bbk
9:1 gears
kelli variator
sef ramp plate
90/90 front and rear tires
dunno what belt would be good with this? just stock belt?
possibly a v8 typhoon exhaust
and the airbox and carb stock
Rains a lot here in san francisco and I read that if water gets into carb through filter it could seize, which is why I was thinking about leaving carb and airbox stock. Lemme know what the experts think about this. Thanks.
malossi bbk with stock carb and airbox?
- paulpauly7
Re: malossi bbk with stock carb and airbox?
if you leave the stock carb (upjetted) and air box then you want to keep a stock exhaust
