Honda Spree Floorboard
fairlead
Post by fairlead »
I have a white Iowa Spree, and I want to paint the floorboard tread black. I DO Not want to replace with a black board. Has anyone tried rattle-can spray on bedliner for this, or have any other suggestions?
85 Iowa Spree
86 Spree Limited Edition
09 Nautilus "Seahorse" (homebuilt)
10 Nautilus "Seabrook" (homebuilt)[/color]
79 Honda Express
67 Harley~Davidson golf cart
vette76
Re: Honda Spree Floorboard
Post by vette76 »
fairlead wrote:I have a white Iowa Spree, and I want to paint the floorboard tread black. I DO Not want to replace with a black board. Has anyone tried rattle-can spray on bedliner for this, or have any other suggestions?
all spray paint basically sucks. and much worse on high wear areas. i would not attempt. i would either replace with a black one, or sand all the bumps out of it, and use skateboard grip tape. which would eventually fail also i would imagine. both should cost about the same.
87' spree (SOLD
12' wrx
beno
Post by beno »
I've used Krylon Fusion spray cans on my Spree and it seems to be holding up pretty well. Lightly sand all of it before hand, that way the paint will have something to grip on to. Just make sure and do plenty of coats especially on the floorboard.
1987 HONDA SPREEEEEEEE
1984 HONDA GYRO NN50!!!
1986 HONDA GYRO!
fairlead
Post by fairlead »
I'll try the fusion. I've had good luck with it too. The off-white color matches my 84 perfectly, I just hate the white floorboard-I'm going black on the tread. A floorboard from a black spree doesn't look the best.
85 Iowa Spree
79 Honda Express
martynkim
Post by martynkim »
Fusion works well on parts that dont have contact like the floor board. I think you will be touching it up. White parts are hard to come by, why not try painting a black one and trimming it out white then your feet wont wear out the paint.
fairlead
Post by fairlead »
Good idea. I may know where two of those are too. I recently acquired an aftermarket petcock cover in black from a member here on ebay. It painted up perfectly with primer, a coat of white, and a coat of off-white.
85 Iowa Spree
79 Honda Express
