tuning a se50 variator
Post by swimmingfree »
it has a ruckus variator and a 3.5 tire when i run 5.5 rollers 0-35 is less then 1 / 8 tack at 8160 35 to 40 tack for ever and will not hit it if a head wind and motor will stay at 8160 rpm ..with 6 gram rollers 0 to 35 is slower tack is at 7840 and will not go higher top speed is 40 ....
question is shoud i go heaver????
thank for your help :happy:
bakaracer
Re: tuning a se50 variator
Post by bakaracer »
you still using that homemade exhaust?
yes.. the tip is the same size as a stock se50 pipe ...
paulpauly7
Post by paulpauly7 »
the tip of the pipe is not the important part the chamber and header pipe lengh is
as you have been told try a stock pipe or get a aftermarket pipe .Your se50 should do at least 45mph the exhaust is holding you back
f the pipe
i looking for info on the variator is it normal for the rpm to drop that munch when you add 1.5 grams rollers. but not lose top speed..
martynkim
Post by martynkim »
swimmingfree wrote:f the pipe
F the pipe? continue to go S-L-O-W.... Listen to what you are told and you won't stay at the back of the pack.... The pipe is key!
i will not pay 60 dollars +40 for shipping for a stock pipe or 210 for a after marked one ....
a nuff with the pipe is as dum as saying put a dio in it.....
bakaracer
Post by bakaracer »
then you will continue having issues. a stock restricted pipe will do 40mph.
paulpauly7
you wont be able to dail in the variater to get good power and top speed without a good exhaust tuned for the motor .You give alot of advise on these forums i kinda thought you know about exhausts and 2 strokes you cant just slap em together and go
last try ...
the trick to tuning the variator is to keep it in the power band??? right??? when you tuning when you do it shood top speed be at the top of the power band or shood it go over the top of the power band ????
bakaracer
Post by bakaracer »
look the pipe is your issue! you cant get it to rev past 8500! a stock unrestricted pipe will rev past 9k and mph wise a stock motor with stock 10to1 gears can topout at around 55mph. your no where near that. for one if your gears are stock and your using that light weight and only change it 1 gram heavier and you go even slower thats why im saying your pipe is tge problem. if your not going to bother and listen then we are done trying to help you. you seem to make like you know everything about these motors so figure it out yourself.
Pineapplegti
Post by Pineapplegti »
I think people confuse a variator with a final drive.. the variator gets the motor to peak rpm ( when tuned correctly) but at the end of the day the final drive determines the top speed. If you are fully variated and only able to run 40 but geared for 50 your motor is not turning the rpm it should. Carb tuning.. pipe etc.. something is wrong.
paulpauly7
its the pipe but he doesnt want to admit it he thinks its as good as a stock pipe and doesnt want to learn :evil:
Pineapplegti
Although I dont really agree with not expansion chamber exhausts on 2strokes a untuned chamber on a 2stroke will not work.
fine ill put up a post on here and see what happen will not hold my breath ..
