Page 1 of 2
Oil Fill
Posted: Sun Jul 09, 2006 8:51 pm
by berreta22
I am in the process of replacing the piston amd rings and what i noticed is the oil level in the crankcase is dirty. I want to change it out but have no clue as to where the oil fill/ drain is. I know this was covered in an earlier topic but was afrais that it was so long ago that none would look back that far to see it. Thanks, info is in my siggy
Posted: Sun Jul 09, 2006 8:54 pm
by noiseguy
Remove or drain fuel/oil tank. Remove plug, tip scoot on side to drain. Fill until no more will go in when level on stand.
Posted: Sun Jul 09, 2006 8:59 pm
by berreta22
where is the plug?? im kinda lost on this im a little slow lol
Posted: Sun Jul 09, 2006 10:05 pm
by noiseguy
All the way on the back, opposite the wheel.
Posted: Sun Jul 09, 2006 10:19 pm
by berreta22
i thought that was just for the rear end and not the engine?
Posted: Mon Jul 10, 2006 10:51 am
by Farfignugin
its a two stroke.............the crankcase oil is the two stroke injector/premix oil...........the oil spot noiseguy explained is for final reduction.
Posted: Mon Jul 10, 2006 6:37 pm
by berreta22
well now that i emptied it all out how much do i put back in there?
Posted: Mon Jul 10, 2006 8:49 pm
by deathwish
the same hole that it came out, if u drained the final reduction oil
Posted: Mon Jul 10, 2006 8:58 pm
by berreta22
the final reduction oil is not the same thing as the oil in the crankcase. It seems no one can give me a stright answer on this.
Posted: Mon Jul 10, 2006 9:24 pm
by Farfignugin
.....the oil for the crankcase is either the two-stroke injector oil that you put into the oil tank under your seat behind the gas tank or if you have taken off the oil pump then it is the pre-mix stuff you put in your gas.
On a two-stroke there is no perminant crankcase oil like there would be in a 4-stroke...
Posted: Mon Jul 10, 2006 9:53 pm
by berreta22
the oil that goes in the crankcase...im about to give up on this. Ok here goes..the oil reservoir..check..the reduction oil...check..the oil that you see when you take off the piston..i wanna fill that up..how much do i put in there?
Posted: Mon Jul 10, 2006 10:03 pm
by noiseguy
It's a two stroke, no oil goes in the bottom end! If there's oil down there puddling up it's a problem.
Posted: Mon Jul 10, 2006 10:12 pm
by berreta22
the what lubricates the connecting rod to the crank? there has to be oil down there!!
Posted: Mon Jul 10, 2006 10:15 pm
by MySpree
ok there is no oil in the crank case, its a dry running system the berings are just greased, we know engines so we know there is no oil in the crankcase, this is a 2 cycle, so it burns oil in its gas, which is done by premixing or in a mopeds case putting oil in the oil tank and haveing it put into the cylinder by the injector. the final reduction oil is just transmission oil, i run synthetic transe oil.
Posted: Mon Jul 10, 2006 10:30 pm
by berreta22
so i just dont put anything in there then? just leave it dry? Now the oil that was in there..did it hurt anything being in there? Thanks
