Idle circuit clear?
Idle circuit clear?
I have been having issues with this d*** thing idling. I tried my damnest to clean out the idle jet. If I put a light to it, I can see a pinhole coming though only if I tilt it to one side looking down the carb linkage hole. I cannot see directly down like you can the main jet. Do I still need to clean it more?
- burnt_toast
Ok, on the two screws...in means richer on air screw and idler faster on idle speed screw?
Ok...just took it for a spin. Still has no power. Even with the new #65 jet. Now I'm just getting *.
Like when it had the bigger jet but not as bad. So, it still won't idle and won't get up to speed...we're talking 15mph max.
- burnt_toast
- Tippmann98
Ok, just tried starting it after it sat overnight. It will start and idle for a bout 30 seconds...slowly slowing down until it eventually stalls. After that, it will not idle on it's own unless I hold the throttle open a bit. This is always the case whenever I come over to my parent's to work on it. This is some frustrating sh*t.
- burnt_toast
if u have my luck, it wont be the choke. ur problem sounds exactly like what i had with my spree. I did the choke test, and that wasnt it. possible in ur case, but i still think that you may have a combination of too lean fuel mixture and clogged pipe.Shane4188 wrote:to me it sounds like the automatic choke/ autobystarter is acting up, in the service manual there is a way to test the choke to see if it is working properly, you may want to try that
too lean= wont idle
clogged pipe= low top speed
that is my opinion.
*edit*
ok, here u go, found the info for tuning a carb. i got mine really clean and it still didnt idle. but after doing some adjusting it idles nicely. this site should help u out:
http://www.scootertherapy.com/carbrepair.html
projects galore
Jerry wrote:My grandson is frequently here with me going over the posts. I understand your frustration Kikwear, but please clean up the language.
I'm not a prude by any means, just respectful of others.
Jerry, welcome back! Hope you're feeling well.
The language needs to clean up, guys. I've been too busy lately to go over all the posts. Now that I have read through more of them, I can see I should have nipped this sooner. Please censor yourselves; there's no need to swear online.
- Tippmann98
