1986 spree key lock
joseramos
1986 spree key lock
Post by joseramos »
when i put my key in lock, i cant seem to pull the key out ! don't know why ! btw I'm new at this !!
patthesoundguy
Re: 1986 spree key lock
Post by patthesoundguy »
Maybe the tumbler and pins are a little gummed up so its not releasing all the way when it goes to the off position. Squirt a bunch of lube in around the key and work it on and off and in and out and spray it again and work it and let it sit and come back spray it again and work it. Maybe it will get some lube in there to release the key. If that won't work you may have to pull the ign switch and get some lube in there.
joseramos
Post by joseramos »
Ok thanks man !
