Best CHT gauge?
JJ Joseph
Best CHT gauge?
Post by JJ Joseph »
From your experience, what is the best, most reliable, most useful, easiest to install CHT gauge for a Dio or Elite? (it should read in Celsius) Thanks in advance.
paulpauly7
Re: Best CHT gauge?
Post by paulpauly7 »
trailtech tto cheap accurate and easy to install
JJ Joseph
Re: Best CHT gauge?
Post by JJ Joseph »
paulpauly7 wrote:trailtech tto cheap accurate and easy to install
From their catalog, the sensor wire is way too short for a scooter. Is there a workaround?
bfowler
Re: Best CHT gauge?
Post by bfowler »
They have extension cables you can order. You'll need one or else it'll be too short
patthesoundguy
Re: Best CHT gauge?
Post by patthesoundguy »
Yes you totally need the extension, I diddnt remember to order one so I extended my sensor on my cht gauge by soldering in more cable, not hard if your solder small wire like I do all the time but still a pain. Would have been worth the money for extension to plug and play.
dun rite
Re: Best CHT gauge?
Post by dun rite »
i used the 48in extension with my elite. to much wire but works great.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
