Hi-
I am having issue with my 1984 Scoot- I had Honda shop bore and I installed new piston and ring set- Scoot will start then die in 1/2 block- Bogs down and will not restart. When I pull spark plug it is wet. New plug will allow it to start but then dies again 1/2 block. I cleaned out carb (Mikuni PB) and flat seem to be plastic and no adjustment possible.
Any Ideas before I lose it?
If I can not get thing reliable it will be for sale in Chicago area
Honda Aero 125
- patthesoundguy
Re: Honda Aero 125
Check and make sure the float floats and isn't full of junk. Also check for clogged exhaust and clogged up air filter.
Re: Honda Aero 125
Wet with fuel or oil? Could be too much assembly lube fouling your plug.
