kickstand
zumacat
kickstand
Post by zumacat »
new at this...the kickstand is loose, do i need to replace that spring?...also, the rear brake cable seems loose and sometimes sticks...nonetheless, i am thrilled that my spree is still running...though, the electric start doesn,t work and recently had to replace the kickstart...i am hoping that i may be able to keep it running, i bought it new in '86 and it has been stolen 3 or 4 times, always to be found and returned to me...i see that as a sign that it is meant to be mine!
Farfignugin
Post by Farfignugin »
wow....
all i have to say is congrats on being the original owner of a spree!
bigbaer
Post by bigbaer »
Replace the spring, it should only run you two or three dollars at a Napa or equivalent parts store. I'd wait for someone elso about the rear brake, I haven't encountered that (yet) and would like to know what to do as well. So all the scratches and gouges are from you, huh? :D Good luck!
'86 Spree, handed down from grandfather-in-law
Either oil or replace the rear cable; funky cables usually aren't worth dealing with.
