kickstand
Posted: Fri Jul 14, 2006 8:07 pm
by zumacat
new at this...the kickstand is loose, do i need to replace that spring?...also, the rear brake cable seems loose and sometimes sticks...nonetheless, i am thrilled that my spree is still running...though, the electric start doesn,t work and recently had to replace the kickstart...i am hoping that i may be able to keep it running, i bought it new in '86 and it has been stolen 3 or 4 times, always to be found and returned to me...i see that as a sign that it is meant to be mine!
Posted: Fri Jul 14, 2006 8:59 pm
by Farfignugin
wow....
all i have to say is congrats on being the original owner of a spree!
Posted: Fri Jul 14, 2006 11:16 pm
by bigbaer
Replace the spring, it should only run you two or three dollars at a Napa or equivalent parts store. I'd wait for someone elso about the rear brake, I haven't encountered that (yet) and would like to know what to do as well. So all the scratches and gouges are from you, huh?
Good luck!
Posted: Sat Jul 15, 2006 11:50 pm
by noiseguy
Either oil or replace the rear cable; funky cables usually aren't worth dealing with.
