How fast does your Spree go ???
so look these are the only rules you have to say your weight and if everything is stock or if you have modified anything big
You guys im heavy im 270 pounds yet spree can do 30mph like nothing i probably can do 35 but once it hits 30 and everything starts vibrating im scared hahaha o and everything is stock !!!
Re: How fast does your Spree go ???
230lbs 25 mph
- Trafficjamz
The top speed of a spree is not determined by your weight.
If your 190 pounds then weight won't Matter but anything bigger than that and weight will matter it will slow it down a bit. There's a weight limit on these sprees
163 LBS.
2.75 rear tire
MLM pipe
34.7 MPH @ 9400 RPM 885 ASL Has turned up to 9,900 RPM didn't have the GPS along .
Every thing else is stock .
2.75 rear tire
MLM pipe
- paulpauly7
im 95kg and my spree does 65.2mph but i swapped in a dio as per my sig
Bro u say ur spree goes 65 I believe you but when I'm doing 30mph my little spree is already shaking cuz it's going too fast ... Have u done anything to stabilize your spree when going at such high speeds ???
paulpauly7 wrote:im 95kg and my spree does 65.2mph but i swapped in a dio as per my sig
- Trafficjamz
If your spree shakes at 30mph, something must be bent.Juanzx wrote:Bro u say ur spree goes 65 I believe you but when I'm doing 30mph my little spree is already shaking cuz it's going too fast ... Have u done anything to stabilize your spree when going at such high speeds ???
It doesn't shake it vibrates a little bit u know like when your going 30mph and u feel the little floard vibrating
Trafficjamz wrote:If your spree shakes at 30mph, something must be bent.Juanzx wrote:Bro u say ur spree goes 65 I believe you but when I'm doing 30mph my little spree is already shaking cuz it's going too fast ... Have u done anything to stabilize your spree when going at such high speeds ???
- paulpauly7
i have a dio zx front disk and shock swap a adjustable rear shock and a frame stablizer
How much would u say all of that cost you ??? Was it allot of work installing everything ??? If you had to choose one thing out of everything u did to it which one would u say it's a must ???
paulpauly7 wrote:i have a dio zx front disk and shock swap a adjustable rear shock and a frame stablizer
Pineapplegti
335 lbs 62.9;)
Wow how the * are you doing 62 mph????
Pineapplegti wrote:335 lbs 62.9;)
- paulpauly7
the disk brake is the best thing not to hard to fit up a little bit of fab work.Now i can stop which is important
How much was the stabilizer and was it worth it ???
paulpauly7 wrote:the disk brake is the best thing not to hard to fit up a little bit of fab work.Now i can stop which is important
