dd50 diy mod help
GuavaJam
dd50 diy mod help
Post by GuavaJam »
So i bought a used dd50, derestricted, pulley, new weights, center sprung, ramp guides, pg exhaust. It has pretty good low-mid range with top speed 45 mph, as my daily ride. R there any doityourself mods to improve gas mileage or power? I dont want it any louder btw lol. Thanks.
GuavaJam
Re: dd50 diy mods
Post by GuavaJam »
What is tire pressure supposed to b?
bobbygerard
Re: dd50 diy mod help
Post by bobbygerard »
I put the pressure on my dd50 to 35 psi
Flying f##cking kangaroo
Sym dd50
Malossi 72cc
Malossi variator 42 gram
Keihin carb 24mm
Japanese clutch white springs
Technigas r exhaust
Top speed 86kph
If you're looking for bragging rights on top speed, use the maximum pressure printed on your tires - uh, sorry - Tyres' - sidewalls. If you're after grip, go softer. Honda uses something in the 20s for PSI but it's been too long. Should be in the Owner's Manual.
patthesoundguy
Post by patthesoundguy »
I run all of my tires at the max pressure on the sidewall. Even on my van. Never had a problem and find I get the best wear and handling. I figure since the weight rating for the tire is based on the max pressure on the sidewall I get the best load capacity with that pressure.
