Keihin 19mm PB carb
Keihin 19mm PB carb
I bought a Keihin 19mm PB carb from Taiwan, only $29 plus shipping, and fitted it onto my Dio. Except for the hole size (19mm) it fits exactly, including the electric bystarter. The bore hole was matched up with a Dremel (the manifold was 14mm and the carb is 19mm), and the performance is awesome. The problem I have now is that I can't find anybody who sells parts for this carb, like needles. The seller doesn't stock parts. Jets are the same as the stock PB, except it needs a 110 size to keep from incinerating the engine. But I need slightly different needles since the needle isn't adjustable like on the stock PB version. Does anybody know where this carb comes from (possibly an ATV?) and where to find parts? This has got to be the cheapest performance blast I've ever come across, so it would be useful to find some kind of parts support for it.
