Two possibly differnt problems
Posted: Tue Jul 18, 2006 12:36 am
by DYLANHSMITH
THe first problem on my 86 spree is that occasionaly after hitting hard bumps or just randomly my spree looses electrical power and just comes to a dead stop, i previously posted the problem thinking it was a problem in the carborator. I cleaned the carb as directed actualy twice. Unfortunataly the problem persisted. I later found that if i touched the two wires going into the box that is on the airfilter that the sparkplug wire goes into it would run again. I thought it could be just a poor connection but i looked it all over and everything seemed fine. That problem seems to occur much less often now but i still have to keep the side panels off so that i can occasionaly "wiggle" the wires to make it run again. The seccond problem is that at full speed the moped is about 2 to 5 mph slower and sounds like it is running poorly at full speed. I thought the problem could be that when i took out the pins in the car that i put them in incorectly but i experimented with them alot and dont think that is the problem. Anny suggestions or ideas on what the problems are or if they are related is appreciated.
Posted: Tue Jul 18, 2006 9:42 am
by Farfignugin
It seems more likely that it is a loose or rusted connection...
Posted: Tue Jul 18, 2006 12:45 pm
by Kenny_McCormic
sounds like you have a loose connection on your coil take out the coil and gease the connectors
Posted: Tue Jul 18, 2006 7:15 pm
by DYLANHSMITH
ok thanks
Posted: Wed Jul 19, 2006 11:00 am
by mopedman
dont hit big bumbs that is how you brake these things
Posted: Wed Jul 19, 2006 4:53 pm
by DYLANHSMITH
i wish i could avoid them because they have caused many other probelms aswell such as breaking the back shock and bending the rims but i ride it offroad alot where big bumps rocks etc are unavoidable at high speed.
