Final drive gasket info NQ 50
trailboss
Post by trailboss »
Does anyone have a source for this gasket, if not I will make an image file from a scanned image of the housing. I make a lot of gaskets using this method.
Take the part, highlight the gasket surface with red sharpie, place on celophane or wax paper on scanner bed, scan, export file to paint or photo shop, clean up and print. Then take the printout and spray some tack spray on new gasket material sticking the two together, then cut/punch out.
I often combine this method with the ball peen hammer method, punching out the bolt holes first, laying the gasket on the part, installing bolts for alignment, then gently peen around with the hammer, makes fast accurate gaskets.
Vin
patthesoundguy
Re: Final drive gasket info NQ 50
Post by patthesoundguy »
Love that idea :-) I'm going to get a scanner just for that purpose ;-) Thank you for sharing that with us :-D two thumbs up.
