Hey Guys,
So trying to get these 9:1 gears offically installed. Noticed that I only have the 9:1 secondary gearset. Did not realize I did not have the main gear shaft that needs to be pressed in. Where can I find the 9:1 main gearshaft and how much do they run? Does anyone on here sell them?
2001 Honda Elite S
9:1 gearset for 2001 Honda Elite S
2001 Honda Elite S (De-restricted)
|Prodigy Variator w/ 9g weights|De-restricted Exhaust|Oil Pump Delete|1.5k Center Clutch Spring|2k Clutch Grabbers|.88 Main Jet|2nd Airbox Tab Removed|9:1 gears|49mph GPS confirmed|
Re: 9:1 gearset for 2001 Honda Elite S
Secondary gear sellers expect the user will press off the OEM gear, and press on their gear.
Honda does not sell the axle as a single part, only as a shaft/gear assembly (23430-GBL-880 GEAR, FINAL (45T) )
If you want to keep your original gear set, post in Wanted/For Sale for a rear axle with/without a gear.
