ax27 belt for spree
lemo97
ax27 belt for spree
Post by lemo97 »
I opened up the clutch cover on my spree and there is lots of black stuff inside so Im assuming I could use an new belt. I heard that the AX27 belt is a good upgrade to the stock belt. Is this the right one http://www.vbeltsupply.com/ecommerce/co ... /ax27.html ? because for $3 I can get these at about 10% of the price I would pay for a new oem one...
patthesoundguy
Re: ax27 belt for spree
Post by patthesoundguy »
Go for it that is the best price going.
lemo97
Post by lemo97 »
apparently you can pick up a few mph by using this belt and for $3 there's no reason not to
patthesoundguy
You can I've done it ;-) you will put back the lost top end from the belt being worn out and put a mph or two on top of that.
