hello, this is my scoot
sef ramp plate
high speed vari
9 to 1 gears
1500 center spring
ct intake 28 mm oko
polini corsa
pg long
i finally got everything put together and broke in. I am running a 55 pilot and 148 main and it is def. to rich i was just wondering what people use or have used with a set up like this as far as jetting goes?
and rollers i took out 3 of the stock rollers and replaced them with 3 gram ones. As im starting to crawl into higher rpms im starting to notice the weigts are a lil on the light side what kinda weights might i want to try i have a roller kit with three of each 3,4,5,6,7,8 i kno i got to try and try and get it right im just more curious of what other people are running really any replys are appreciated thanks
2001 sa50 jetting.
- swimmingfree
Re: 2001 sa50 jetting.
i took out 3 of the stock rollers and replaced them with 3 gram ones. rollers shood not be more the one gram between them As im starting to crawl into higher rpms im starting to notice the weigts are a lil on the light side what kinda weights might i want to try i have a roller kit with three of each 3,4,5,6,7,8 i kno i got to try and try and get it right im just more curious of what other people are running really any replys are appreciated thanks
its nor hard
stock roller wate times 3 = ??? 3 grams times 3 = 9 grams then add 9 plus ??? = ??? then dive by 6 =???
its nor hard
- paulpauly7
in my setup in my sig im running 3 5.5grams and 3 6gram rollers works nice rpms pick up to 10200 and stay around that till the cvt has finished its job
t8kinover.
- BMX
well thanks I had no idea about the rollers. I'm kinda having issues with the idle circuit I'm down to a 40 jet I'm going to try adjusting the needle see if that helps.
I kno it's not part of the same circut.
Sent from my SCH-I500 using Tapatalk 2
- paulpauly7
did you port the cases ? Do you have a temp guage?
t8kinover.
- BMX
yes and yes. I ordered some smaller slow jets. surprisingly dropping the needle did help!
