Dio gear ratio/ variator/ carb mm advice needed......
Hey guys, The past few months I have been building a AF16 motor. I'm sure it's close to the same as everyone else's! With a different crank, a corsa, clutch and variator. I'm looking for a nice top end (somewhere in the neighborhood of 65+) BUT I want to get there quick!!! So I'm looking for some advice on gear ratio,variator weights and carb mm....I know it's not going to all happen at the first try and understand it's alot of trail and error (but with everyone on here I think I have a should have a good shot at more trail then error) Just looking for some input so I can put this together and feel my money was well spent!!!! Thanks......
- paulpauly7
Re: Dio gear ratio/ variator/ carb mm advice needed......
ive got the setup in my sig ive had it up to 70mph but that was on a slight down hill but 65mph on the flat .My take off is awesome im running 5k clutch springs
